XREFNOTIFY system variable
Xref notify
Enables/disables the notification about missing xrefs when opening the parent drawing.
Type: | Boolean |
Saved in: | Registry |
Possible values: |
Off (0): Disable xref notification On (1): Enable xref notification |
