XREFOVERRIDE system variable
Xref override
Specifies the display of entity visual properties (such as color, linetype, lineweight, transparency, or plot style) on referenced layers.
If Off (0): When the properties of the entities on the XREF drawing are set to ByLayer, any changes to the xref layer properties are displayed in the current drawing.
If On (1): When the properties of the entities on the XREF drawing are not set to ByLayer, entities on xref layers are treated as if their properties are set to ByLayer. And every external reference layer can have its own set of layer overrides.
Type:
Short
Saved in:
Drawing
Range:
0 to 1
Default value:
0
Possible values:
Off (0): Only ByLayer properties of the entities in the XREF drawing can be changed
On (1): All properties of entities in the XREF drawing can be changed by its original layer property
