ZOOMFACTOR system variable
Zoom factor
Specifies the incremental change in zoom with each mouse-wheel action, whether forward or backward. When zooming in, the incremental step decreases gradually allowing to focus on a particularly detail easily. Values between 3 and 100 are accepted. The higher the number, the more the change.
Type:
Short
Saved in:
Registry
Range:
3 to 100
Default value:
40
