Project folders migration to the new user interface
We have decluttered and simplified the folder structure to improve usability and give everyone in the project a clearer view.
For existing projects, this required project folders to be migrated to the new UI, supporting our newly separated Tools (also known as Apps) structure in Files (Documents, Binders, and BIM), Address book, Forms, Messages, etc.
:What’s changed?
Only Document, Binder and BIM folders will support Document and Binder subfolders.
For example: A Document folder with a Messages or Address Book subfolder has been separated.
- BIM folders are now contained within the Files app, alongside Documents and Binder folders.
- Documents, Binder and BIM folders cannot have BIM subfolders.
No information, data or other project configuration has been lost or changed.
Only relevant subfolders have been relocated by app (for example: Address book, Forms, Mail etc.).
You cannot switch back to the old folder structure, but you can reorganise your newly migrated folder structure using the folder drag handles:
Projects will feel more organised, with a more familiar layout. We hope this new structure will make 24/7 easier and more clear for everyone to use.
