How to import custom aliases, toolbars, and shortcuts from older BricsCAD versions?
Older menu files (*.mnu) can be imported in BricsCAD using:
  • The MENULOAD dialog box: Browse for the MNU file and then click Load
  • the Customize dialog box: click Load partial CUI file from the File menu and then just select file type MNU in the Open File dialog. The MNU file will be silently converted to the new CUI format.
