How to load program parameters files (ICA or PGP files)?
Symptoms
The MENULOAD command does not support ICA files nor PGP files.
Cause
Analog to AutoCAD, the MENULOAD and MENU commands only accept CUI and MNU files, no ICA or PGP files.
Solution
The command aliases can be edited in the Customize Dialog, in the Command Aliases and Shell Commands tabs.
An other way to customize command aliases, is to edit or overwrite the default.pgp file. The REINIT command reloads the aliases from this file.
