BricsCAD registry structure
The language version of BricsCAD is defined by the presence of a subfolder next to bricscad.exe, with a name that represents a valid locale, i.e. of the format la_CO, la being two lowercase letters specifying the language, CO two uppercase letters specifying the country.
Anything that BricsCAD writes/reads in the registry is first subdivided per major version (V22, V23..) and platform: e.g. V23 for a 32 bit version and V23x64 for a 64 bit version, written as Vx below, then per language (en_US, fr_FR, .. written as la_CO below).
  • This value in the registry contains the most recently used major version of BricsCAD:
    CURVER in HKEY_CURRENT_USER\Software\Bricsys\Bricscad
  • This value in the registry contains the most recently used language for BricsCAD Vx:
    CURVER in HKEY_CURRENT_USER\Software\Bricsys\Bricscad\Vx
  • This value in the registry contains the most recently installed language for BricsCAD Vx:
    CURVER in HKEY_LOCAL_MACHINE\Software\Bricsys\Bricscad\Vx
  • All BricsCAD Vx la_CO user settings and profiles can be found in :
    HKEY_CURRENT_USER\Software\Bricsys\Bricscad\Vx\la__CO
  • All BricsCAD Vx la_CO installation information can be found in:
    HKEY_LOCAL_MACHINE\Software\Bricsys\Bricscad\Vx\la_CO
  • Below is a list of available languages for BricsCAD:
    • cs_CZ
    • de_DE
    • en_US
    • es_ES
    • fr_FR
    • it_IT
    • ja_JP
    • ko_KR
    • lt_LT
    • pl_PL
    • pt_BR
    • ro_RO
    • ru_RU
    • zh_CN
    • zh_TW
