Reprise error codes
General Licensing Errors:
Status Value Meaning
RLM_EH_NOHANDLE -101 No handle supplied to call
RLM_EH_READ_NOLICENSE -102 Can't read license data
RLM_EH_NET_INIT -103 Network (msg_init()) error
RLM_EH_NET_WERR -104 Error writing to network
RLM_EH_NET_RERR -105 Error reading from network
RLM_EH_NET_BADRESP -106 Unexpected response
RLM_EH_BADHELLO -107 HELLO message for wrong server
RLM_EH_BADPRIVKEY -108 Error in private key
RLM_EH_SIGERROR -109 Error signing authorization
RLM_EH_INTERNAL -110 Internal error
RLM_EH_CONN_REFUSED -111 Connection refused at server (this can also happen if you have a bad TCP/IP address in your local database)
RLM_EH_NOSERVER -112 No server to connect to
RLM_EH_BADHANDSHAKE -113 Bad communications handshake
RLM_EH_CANTGETETHER -114 Can't get ethernet address
RLM_EH_MALLOC -115 malloc() error
RLM_EH_BIND -116 bind() error
RLM_EH_SOCKET -117 socket() error
RLM_EH_BADPUBKEY -118 Error in public key
RLM_EH_AUTHFAIL -119 Authentication failed
RLM_EH_WRITE_LF -120 Can't write new license file
RLM_EH_DUP_ISV_HID -122 ISV-defined hostid already registered
RLM_EH_BADPARAM -123 Bad parameter passed to RLM function
RLM_EH_ROAMWRITEERR -124 Roam File write error
RLM_EH_ROAMREADERR -125 Roam File read error
RLM_EH_HANDLER_INSTALLED -126 Heartbeat handler already installed
RLM_EH_CANTCREATELOCK -127 Can't create 'single' lockfile
RLM_EH_CANTOPENLOCK -128 Can't open 'single' lockfile
RLM_EH_CANTSETLOCK -129 Can't set lock for 'single'
RLM_EH_BADRLMLIC -130 Bad/missing/expired RLM license
RLM_EH_BADHOST -131 bad hostname in license file or port@host
RLM_EH_CANTCONNECTURL -132 Can't connect to specified URL (activation)
RLM_EH_OP_NOT_ALLOWED -133 Operation not allowed on server. The status reread shutdown or remove command has been disabled for this user.
RLM_EH_ACT_BADSTAT -134 Bad status return from Activation server
RLM_EH_ACT_BADLICKEY -135 Activation server built with incorrect license key
RLM_EH_ACT_BAD_HTTP -136 Error in HTTP transaction with Activation server
RLM_EH_DEMO_EXISTS -137 Demo already created on this system
RLM_EH_DEMO_WRITEERR -138 Demo install file write error
RLM_EH_NO_DEMO_LIC -139 No rlm_demo license available
RLM_EH_NO_RLM_PLATFORM -140 RLM is unlicensed on this platform
RLM_EH_EVAL_EXPIRED -141 The RLM evaluation license compiled into this binary has expired
RLM_EH_SERVER_REJECT -142 Server rejected (too old)
RLM_EH_UNLICENSED -143 Unlicensed RLM option
RLM_EH_SEMAPHORE_FAILURE -144 Seamphore initialization failure
RLM_EH_ACT_OLDSERVER -145 Activation server too old (doesn't support encryption)
RLM_EH_BAD_LIC_LINE -146 Invalid license line in LF
RLM_EH_BAD_SERVER_HOSTID -147 Invalid hostid on SERVER line
RLM_EH_NO_REHOST_TOP_DIR -148 No rehostable hostid top-level dir
RLM_EH_CANT_GET_REHOST -149 Cannot get rehostable hostid
RLM_EH_CANT_DEL_REHOST -150 Cannot delete rehostable hostid
RLM_EH_CANT_CREATE_REHOST -151 Cannot create rehostable hostid
RLM_EH_REHOST_TOP_DIR_EXISTS -152 Rehostable top directory exists
RLM_EH_REHOST_EXISTS -153 Rehostable hostid exists
RLM_EH_NO_FULFILLMENTS -154 No fulfillments to revoke
RLM_EH_METER_READERR -155 Meter read error
RLM_EH_METER_WRITEERR -156 Meter write error
RLM_EH_METER_BADINCREMENT -157 Bad meter increment command
RLM_EH_METER_NO_COUNTER -158 Can't find counter in meter
RLM_EH_ACT_UNLICENSED -159 Activation Unlicensed
RLM_EH_ACTPRO_UNLICENSED -160 Activation Pro Unlicensed
RLM_EH_SERVER_REQUIRED -161 Counted license requires server
RLM_EH_DATE_REQUIRED -162 REPLACE license requires date
RLM_EH_NO_METER_UPGRADE -163 METERED licenses can't be UPGRADED
RLM_EH_NO_CLIENT -164 Disconnected client data can't be found
RLM_EH_NO_DISCONN -165 Operation not allowed on disconnected handle
RLM_EH_NO_FILES -166 Too many open files
RLM_EH_NO_BROADCAST_RESP -167 No response to broadcast message
RLM_EH_NO_BROADCAST_HOST -168 Broadcast response didn't include hostname
RLM_EH_SERVER_TOO_OLD -169 Server too old for disconnected operations In addition rlm_act_request() will return the following errors:I
Internet Activation Errors:
RLM_ACT_BADPARAM -1001 Unused – RLM_EH_BADPARAM returned instead.
RLM_ACT_NO_KEY -1002 No activation key supplied
RLM_ACT_NO_PROD -1003 No product definition exists
RLM_ACT_CANT_WRITE_KEYS -1004 Can't write keyf table
RLM_ACT_KEY_USED -1005 Activation key already used
RLM_ACT_BAD_HOSTID -1006 Missing hostid
RLM_ACT_BAD_HOSTID_TYPE -1007 Invalid hostid type
RLM_ACT_BAD_HTTP -1008 Bad HTTP transaction. Note: unused after v3.0BL4
RLM_ACT_CANTLOCK -1009 Can't lock activation database
RLM_ACT_CANTREAD_DB -1010 Can't read activation database
RLM_ACT_CANT_WRITE_FUFILL -1011 Can't write licf table
RLM_ACT_CLIENT_TIME_BAD -1012 Clock bad on client system (not within 7 days of server)
RLM_ACT_BAD_REDIRECT -1013 Can't write licf table
RLM_ACT_TOOMANY_HOSTID_CHANGES -1014 Too many hostid changes for refresh-type activation
RLM_ACT_BLACKLISTED -1015 Domain on blacklist for activation
RLM_ACT_NOT_WHITELISTED -1016 Domain not on activation key whitelist
RLM_ACT_KEY_EXPIRED -1017 Activation key expired
RLM_ACT_NO_PERMISSION -1018 HTTP request denied (this is a setup problem)
RLM_ACT_SERVER_ERROR -1019 HTTP internal server error (usually a setup problem)
RLM_ACT_BAD_GENERATOR -1020 Bad/missing generator file (Activation Pro)
RLM_ACT_NO_KEY_MATCH -1021 No matching activation key in database
RLM_ACT_NO_AUTH_SUPPLIED -1022 No proxy authorization supplied
RLM_ACT_PROXY_AUTH_FAILED -1023 Proxy authentication failed
RLM_ACT_NO_BASIC_AUTH -1024 No basic authentication supported by proxy
RLM_ACT_GEN_UNLICENSED -1025 Activation generator unlicensed (ISV_mklic)
RL_ACT_DB_READERR -1026 Activation database read error (Activation Pro)
RLM_ACT_GEN_PARAM_ERR -1027 Generating license - bad parameter
RLM_ACT_UNSUPPORTED_CMD -1028 Unsupported command to license generator
BOA_KEY_INACTIVE -1030 Key is not Active in BOA (probably upgraded)
RLM_ACT_BAD_URL -1036
The URL in the rlm_activate() call is
incorrect, or your license generator is not present or not executable.
License Checkout Errors:
RLM_EL_NOPRODUCT -1 No authorization for product rlm_checkout() did not find a product to satisfy your request.
RLM_EL_NOTME -2 Authorization is for another ISV The license you are requesting is in the license file but it is for a different ISV.
RLM_EL_EXPIRED -3 Authorization has expired.
RLM_EL_NOTTHISHOST -4 Wrong host for authorization The hostid in the license doesn't match the hostid of the machine where the software is running.
RLM_EL_BADKEY -5 Bad key in authorization The signature in the license line is not valid i.e. it does not match the remainder of the data in the license.
RLM_EL_BADVER -6 Requested version not supported Your application tried to check out a license at a higher version than was available e.g. you specified v5 but the available license is for v4.
RLM_EL_BADDATE -7 bad date format -not permanent or dd-mm-yy The expiration start or issued date wasn't understood eg 316-mar-2010 or 31-jun-2010. You'd probably never see this in the field unless somebody had tampered with the license file.
RLM_EL_TOOMANY -8 checkout request for too many licenses Your checkout request will never work because you have asked for more licenses than are issued.
RLM_EL_NOAUTH -9 No license auth supplied to call This is an internal error.
RLM_EL_ON_EXC_ALL -10 On excludeall list The license administrator has specified an EXCLUDEALL list for this product and the user (host etc) is on it.
RLM_EL_ON_EXC -11 On feature exclude list The license administrator has specified an EXCLUDE list for this product and the user (host etc) is on it.
RLM_EL_NOT_INC_ALL -12 Not on the includeall list The license administrator has specified an INCLUDEALL list for this product and you are not on it.
RLM_EL_NOT_INC -13 Not on the feature include list The license administrator has specified an INCLUDE list for this product and you are not on it.
RLM_EL_OVER_MAX -14 Request would go over license MAX The license administrator set a license MAX usage option for a user or group. This checkout request would put this user/group/host over that limit.
RLM_EL_REMOVED -15 License (rlm)removed by server A license administrator removed this license using the rlmremove command or the RLM web interface.
RLM_EL_SERVER_BADRESP -16 Unexpected response from server The application received a response from the license server which it did not expect. This is an internal error.
RLM_EL_COMM_ERROR -17 Error communicating with server This indicates a basic communication error with the license server either in a network initilization read or write call.
RLM_EL_NO_SERV_SUPP -18 License server doesn't support this
RLM_EL_NOHANDLE -19 No license handle No license handle supplied to an rlm_get_attr_xxx() call or rlm_license_xxx()
RLM_EL_SERVER_DOWN -20 Server closed connection The license server closed the connection to the application.
RLM_EL_NO_HEARTBEAT -21 No heartbeat response received Your application did not receive a response to a heartbeat message which it sent. This would happen when you call rlm_get_attr_health() or automatically if you called rlm_auto_hb().
RLM_EL_ALLINUSE -22 All licenses in use All licenses are currently in use and the user did not request to be queued. This request will succeed at some other time when some licenses are checked in.
RLM_EL_NOHOSTID -23 No hostid on uncounted license Uncounted licenses always require a hostid.
RLM_EL_TIMEDOUT -24 License timed out by server Your application did not send any heartbeats to the license server and the license administrator specified a TIMEOUT option in the ISV server options file.
RLM_EL_INQUEUE -25 In queue for license All licenses are in use and the user requested queueing by setting the RLM_QUEUE environment variable.
RLM_EL_SYNTAX -26 License syntax error This is an internal error.
RLM_EL_ROAM_TOOLONG -27 Roam time exceeds maximum The roam time specified in a checkout request is longer than either the license-specified maximum roaming time or the license administrator's ROAM_MAX_DAYS option specification.
RLM_EL_NO_SERV_HANDLE -28 Server does not know this license handle This is an internal server error. It will be returned usually when you are attempting to return a roaming license early.
RLM_EL_ON_EXC_ROAM -29 On roam exclude list The license administrator has specified an EXCLUDE_ROAM list for this product and the user (host etc) is on it.
RLM_EL_NOT_INC_ROAM -30 Not on the roam include list The license administrator has specified an INCLUDE_ROAM list for this product and you are not on it.
RLM_EL_TOOMANY_ROAMING -31 Too many licenses roaming already A request was made to roam a license but there are too many licenses roaming already (set by the license administrator ROAM_MAX_COUNT option).
RLM_EL_WILL_EXPIRE -32 License expires before roam period ends A roaming license was requested but the only license which can fulfill the request will expire before the roam period ends.
RLM_EL_ROAMFILEERR -33 Problem with roam file There was a problem writing the roam data file on the application's computer.
RLM_EL_RLM_ROAM_ERR -34 Cannot check out rlm_roam license A license was requested to roam but the application cannot check out an rlm_roam license.
RLM_EL_WRONG_PLATFORM -35 Wrong platform The license specifies platforms=xxx but the for client application is not running on one of these platforms.
RLM_EL_WRONG_TZ -36 Wrong timezone for client The license specifies an allowed timezone but the application is running on a computer in a different timezone.
RLM_EL_NOT_STARTED -37 License start date in the future The start date in the license hasn't occurred yet e.g. today you try to check out a license containing start=1-mar-2030.
RLM_EL_CANT_GET_DATE -38 time() call failure The time() system call failed
RLM_EL_OVERSOFT -39 Request goes over license soft_limit This license checkout causes the license usage to go over it's soft limit. The checkout is successful but usage is now in the overdraft mode.
RLM_EL_WINDBACK -40 Clock setback detected RLM has detected that the clock has been set back. This error will only happen on expiring licenses.
RLM_EL_BADPARAM -41 Bad parameter to rlm_checkout() call This currently happens if a checkout request is made for < 0 licenses.
RLM_EL_NOROAM_FAILOVER -42 Roam operations not allowed on failover server A failover server has taken over for a primary server and a roaming license was requested. Roaming licenses can only be obtained from primary servers. Re-try the request later when the primary server is up.
RLM_EL_BADHOST -43 bad hostname in license file or port@host The hostname in the license file is not valid on this network.
RLM_EL_APP_INACTIVE -44 Application is inactive Your application is set to the inactive state (with rlm_set_active(rh 0) and you have called rlm_get_attr_health().
RLM_EL_NOT_NAMED_USER -45 User is not on the named-user list You are not on the named user list for this product.
RLM_EL_TS_DISABLED -46 Terminal server/remote desktop disabled The only available license has Terminal Server disabled and the application is running on a Windows Terminal Server machine.
RLM_EL_VM_DISABLED -47 Running on Virtual Machines disabled The only available license has virtual machines disabled and the application is running on a virtual machine.
RLM_EL_PORTABLE_REMOVED -48 Portable hostid removed The license is locked to a portable hostid (dongle) and the hostid was removed after the license was acquired by the application.
RLM_EL_DEMOEXP -49 Demo license has expired Detached Demotm license has expired.
RLM_EL_FAILED_BACK_UP -50 Failed host back up - failover server released license If you application is holding a license from a failover server when the main server comes back up the failover server will drop all the licenses it is serving and you will get this status.
RLM_EL_SERVER_LOST_XFER -51 Server lost it's transferred license Your license was served by a server which had received transferred licenses from another ay have gone down in which case your server will lose the licenses which were transferred to it.
RLM_EL_BAD_PASSWORD -52 Incorrect password for product RLM_EL_BAD_PASSWORD is an internal error and won't ever be returned to the client - if the license password is bad the client will receive RLM_EL_NO_SERV_SUPP
RLM_EL_METER_NO_SERVER -53 Metered licenses require server Metered licenses only work with with a license server.
RLM_EL_METER_NOCOUNT -54 Not enough count for meter There is insufficient count in the meter for the requested operation.
RLM_EL_NOROAM_TRANSIENT -55 Roaming not allowed Roaming is not allowed on servers with transient hostids ie dongles.
RLM_EL_CANTRECONNECT -56 Can't reconnect to server On a disconnected handle the operation requested needed to reconnect to the server and this operation failed.
RLM_EL_NONE_CANROAM -57 None of these licenses can roam The license max_roam_count is set to 0 This will always be the case for licenses that are transferred to another server.
RLM_EH_SERVER_TOO_OLD -58 Server too old for this operation In v10 this error means that disconnected operation (rlm_init_disconn()) was attempted on a pre-v10.0 license server.
