How to add BricsCAD to an existing RLM setup?
  1. Download the Network License Installer from the following link:
    https://www.bricsys.com/bricscad/tools/Bricsys-NetworkLicenseManager.msi
  2. Install the package. Make sure that the tickboxes prompted on installation are not checked.
  3. Obtain your license file in one of two ways:
    • Run actNetworkLicense.exe (installed in C:\Program Files\Bricsys\Bricsys Network License Manager), which generates a Bricsys.lic file in the folder specified in the activation dialog.
    • Do a manual activation, as described in the BricsCAD Help.
  4. Copy the following files to your RLM install directory:
    • bricsys.set (found in C:\Program Files\Bricsys\Bricsys Network License Manager).
    • The license file obtained by the previous step.
    • OPTIONAL: replace the rlm.exe you have installed with our version of rlm.exe (some features will not be available on an older version).
  5. Perform a Reread/Restart of your RLM instance.
