Performing remote configuration of workstations
How to perform the remote configuration of workstations in order to indicate to Bricsys License Manager what is the license server address at activation?
  1. All user machines must be in the same LAN with the server, either physically or through a VPN connection.
  2. Then you can activate all the machines at once by deploying a .txt file saved with a *.lic extension in the C:\ProgramData\Bricsys path for all user machines.
    The file should contain the following row:
    HOST <servername> ANY <port>
    For example: HOST RLMServer ANY 5053.
