account
translation
Bricsys Help Center
How to revoke an activation after system crash?
  • База знаний
    • Maintenance offer
    • Where can I find the release notes?
    • Apple compatibility for BricsCAD
    • Where can I find offline Help for current and previous BricsCAD versions?
    • Bricsys Beta Tester Program
    • TAA Compliance
    • Installation
      • BricsCAD registry structure
      • How can I install run VBA?
      • How to repair or perform a clean BricsCAD installation?
      • Install and use BricsCAD on a Citrix server
      • Local support files (default.pgp, classic-ribbon.cui) are missing or out of date
      • Multiple installations of the same BricsCAD version
      • When and how is BricsCAD initialized using root folders?
      • When I upgrade to the latest build will I lose my registration info?
      • Where can I download older BricsCAD releases?
      • Registry settings and files installed by BricsCAD
      • Error during installation on Linux when previous version of BricsCAD is detected
    • Лицензирование
      • Failure to add license key on Windows Vista or higher
      • How can I see which computers are using a Volume license?
      • How can I see which license key is in use on a computer?
      • How to migrate my license to another computer?
      • How to revoke an activation after system crash?
      • How to run BricsCAD in a lower license level?
      • How to try out an unavailable command?
      • Where can I find my licenses?
      • Windows 11 Upgrade
      • Network licenses
        • How to add BricsCAD to an existing RLM setup?
        • How to move a network license to another server?
        • How to use multiple Network licenses with different levels?
        • Performing remote configuration of workstations
        • Network license on Linux
        • Network license server: Service install failed.
        • Where is the license file on a network license server?
      • Error codes
        • Licensing error 2 (Error writing license file)
        • Licensing error -3 (Your license for this product has expired)
        • Licensing error -4 (The license for this product is locked to another computer or is using an invalid hostid)
        • Licensing errors -4 / -1 (License activated as administrator cannot be used by other users)
        • Licensing error -17 (BricsCAD cannot connect to a network license server)
        • Licensing error -18 (No license for this product on the license server. Please contact your license administrator)
        • Licensing error -43 (Bad hostname LF/port@host)
        • Licensing error -46 (Terminal server disabled)
        • Licensing error -103 (missing internet connection)
        • Licensing error -105 (Error reading from network)
        • Licensing errors -132 / -136 (Cannot connect to the Bricsys License Activation Server)
        • Licensing error -153 (When activating BricsCAD on macOS or Linux)
        • Licensing error -1005 (Key already used)
        • Licensing error -1007 (Manual license activation fails)
        • Licensing error -1030 (Unknown error)
        • Licensing error -1036 (Unknown error)
        • Reprise error codes
      • How to setup a network license on a failover server
      • How to switch from a trial to a Commercial license
    • Printing
      • How to correctly display text in PDF documents?
      • Why do images, PDF underlays or OLE objects partially printed or as black filled rectangles?
      • Why does printing ignore plotstyles?
      • Why does the PRINT dialog take so long to open?
      • Why Gradient Hatches print as black fills?
    • Customizing
      • How can I customize BricsCAD's right-click behavior?
      • How to create a keyboard shortcut?
      • How to customize the right and middle mouse buttons?
      • How to import custom aliases, toolbars, and shortcuts from older BricsCAD versions?
      • How to load program parameters files (ICA or PGP files)?
      • What is BSB (BricsCAD Solution Build)?
      • What are Bricsys LGS components?
    • Troubleshooting
      • Why are my customizations lost after the update?
      • How to fix the error: Can't create file [SomePath]\Desktop.ini?
      • How to fix the error: Failed to update the system registry?
      • How to fix the error: file not found: vba.6dll?
      • How to fix the corrupted "default.cui" file at BricsCAD startup?
      • How to fix the REDSDK error?
      • How to mitigate crash caused by USB dock
      • How to reset the user interface to defaults?
      • How to start BricsCAD in Safe Mode, without any applications?
      • How to stop BricsCAD crashing during startup?
      • How to recover from a crash
      • What files are automatically loaded by BricsCAD?
      • What files to include when reporting crashes?
      • Why are some hatch patterns displayed distorted?
      • Why are the toolbar icons displayed as question marks?
      • Why are menus not displayed in the main CUI file?
      • Why certain fonts display wrong characters?
      • Why do trailing afterimages or ghosts appear when dragging toolbars and dockable panels?
      • Why does changing the position and visibility of the toolbar have no effect?
      • Why the default.cui is reverted at startup?
      • Why is the third-party application not working?
      • Why tools from MNU/MNS are missing in CUI?
      • Why UNDO reverts too many operations?
      • How does MLeader left align works?
    • How to
      • How can I copy blocks and layers from one drawing to another drawing?
      • How can I insert a spreadsheet into a drawing?
      • How can I use an external multiline text editor?
      • How to change the background color?
      • How to change the order of drawing elements?
      • How to connect the Tablet to BricsCAD?
      • How to create a plot file (*.plt)?
      • How to open Bricsys ebooks on macOS?
      • How to optimize polylines converted from lwpolylines?
      • How to Publish to DWF?
      • How to PURGE the DGN linetypes from Microstation import?
      • How to read CSV files in other programs?
      • How to use resource DLLs for toolbar icons?
      • How to use the preprocessor.exe in order to ignore GeoTIFF tags while preprocessing non standard .LAS, .LAZ pointcloud data?
      • How to create useful backtrace on Linux
      • How to solve customization issues for Places bar
      • How to manage images/xref paths?
    • Customer service and website
      • My Bricsys Account
      • How to add Organization Info
      • Where can I change my mailing subscriptions
      • How to solve 'this email address already exists'?
      • Log4j security issue
    • Bricsys 24/7
      • Links migration to Forms
      • The new user interface
      • Project folders migration to the new user interface
      • Where can I find offline Help for Bricsys 24/7?
See the Deactivating or revoking a BricsCAD license article.
Note: The number of revocations is limited.
Parent topic: База знаний
Parent topic: Лицензирование
Related information
  • Deactivating or revoking a BricsCAD license
© 2023 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
