How to run BricsCAD in a lower license level?
Symptoms
I would like to check the availability of a feature in a lower license level.
Cause
The availability of a feature depends on the license level.
Solution
To run BricsCAD in a lower license level use the SETLICENSELEVEL command. This facilitates the evaluation of the features available for each license level, by changing the commands that are available to the user.
Note: All features are available in a trial license.
