How to switch from a trial to a Commercial license
The trial license file takes precedence over the other license files.
If you want BricsCAD to use the Commercial license:
  1. Go to C:\ProgramData\Bricsys and delete the trial license file.
    Note: The trial license file should contain the following syntax:
    contract=Trial
    You can see the license file content by opening it in a text editor/viewer.
  2. Add your Commercial licence in the Bricsys License Manager dialog box.
