How to try out an unavailable command?
Symptoms
I would like to use a command, but I get a message that it requires a certain license.
Cause
Some commands are available in a higher license level only. The necessary license level for each command is indicated in the Command reference.
Solution
Open a Support Request. Bricsys will send you a trial license key, which enables you to try the advanced features for a 30 days limited time period.
When the trial license key expires, you have to re-enter your old license key using the same procedure.
You can find all you licenses in Bricsys website.
on theNote: You can always install the latest BricsCAD version in trial mode, which uses
the highest license level.
