Licensing error -46 (Terminal server disabled)
Symptoms
I try to activate a trial and the error Terminal server disabled is displayed, and BricsCAD does not start.
Cause
BricsCAD only runs on a terminal server with a network license, otherwise the number of users of the license is not controllable.
Solution
You can try BricsCAD on another machine. If you want to purchase a license, you will have to purchase a network license. If you want to try the network license, contact support to request for a trial network license.
