Licensing error -153 (When activating BricsCAD on macOS or Linux)
Symptoms
When trying to activate BricsCAD on macOS or Linux, error -153 appears.
Solution
Option 1
In a Terminal instance, run the following commands one by one:
sudo rm -rf /var/bricsys
sudo rm -rf /var/tmp/br*
sudo mkdir /var/bricsys
sudo chmod 777 /var/bricsys
Then try to activate again.
Option 2 (if Option 1 did not solve the issue)
Erase the following folders:
/var/bricsys
/var/tmp/bricsys
Note: If the above solutions fail, activate your license manually. See the Single or volume license: offline (manual) activation article for more information.
