How to fix the error: file not found: vba.6dll?
Symptoms
When running a VBA macro the following error pops up:
error: "file not found: vba.6dll"
Cause
This is probably caused by the installation of another application that installs VBA 7. This installation can cause corruption of a VBA 6 registry key, that causes an incorrect reference to the VBA 6 dll's.
Solution
A possible solution is suggested on this link: https://www.excelforum.com/excel-programming-vba-macros/666088-file-not-found-vba6-dll.html
If registering VBE6.dll a does not help, have a look at the value of the following registry key:
"HKEY_CLASSES_ROOT\TypeLib\{000204EF-0000-0000-C000-000000000046}\6.0\9\win32"
Maybe it points to a non-existent file, e.g., on a 64 bit system:
C:\\Windows\\SysWOW64\\msvbvm60.dll
In that case, try changing it to:
C:\Program Files (x86)\Common Files\Microsoft Shared\VBA\VBA6\VBE6.DLL
