How to mitigate crash caused by USB dock
Symptoms
BricsCAD sometimes crashes at startup or when switching to rendered visual styles (3D) if a multiple video connections USB dock is connected to the machine.
Cause
This happens because Windows classifies this dock's chipset as a display adaptor, and BricsCAD tries to use it as a graphic card.
Solution
Since this can not be fixed/controlled by us, please find below some possible workarounds:
  • Connect only one monitor through the USB docking station and the other/s on HDMI/DP laptop port (BricsCAD will use Nvidia).
  • Set as 'main' monitor in Windows Display Settings the laptop builtin display (BricsCAD will use Nvidia).
  • Disable Intel iGPU from Windows Device Manager (BricsCAD will use Nvidia).
  • Remove the USB dock from the configuration.
