How to reset the user interface to defaults?
Symptoms
Menus, toolbars and/or ribbon have disappeared.
Cause
  • You accidentally closed menus, toolbars, or the ribbon.
  • Something went wrong when customizing BricsCAD.
Solution
Do the following:
  1. Launch the CUSTOMIZE command.
    The Customize dialog box displays.
  2. Click the Manage your customizations... button.
    The Manage your customizations dialog box displays.
  3. Click the Revert to defaults button, then click the OK button.
    The Manage your customizations dialog box closes.
  4. Click the OK button to close the Customize dialog box.
    The default settings for the current workspace are restored.
