Why is the third-party application not working?
Symptoms
The third-party application does not work in BricsCAD.
Cause
- The application does not support your BricsCAD version.
- VBA is not running.
Solution
If you are using third party applications on BricsCAD, make sure they are compatible with your BricsCAD version. See the application details in our Application catalog.
Note: See also How can I install / run VBA? in the BricsCAD Knowledge
Base.
