Attaching compositions
Commands
BIMATTACHCOMPOSITION, BLCOMPOSITIONS
About BIM attach composition
See BIMATTACHCOMPOSITION for more information about attaching a composition.
See BIM Compositions for more information about managing compositions.
Attaching a composition
To attach a composition, you can:
- Use the BIMATTACHCOMPOSITION command.
- Drag a composition from the BIM Compositions panel on the solid(s).
- Launch the BIMATTACHCOMPOSITION command.
You are prompted: Enter the composition name or [Dialog/Entity] <Dialog>.
- Do one of the following:
- Type a composition name in the Command line and press Enter.Note: Composition names are case sensitive.
- Press Enter to display the Compositions dialog and click on a Composition in the In Project or In Library list to open the menu of the composition.
If you want to select the composition without opening the menu, double-click it.
- Choose a Composition Type from the drop-down menu and press Select to accept.
- Select entities to attach the composition to and press Enter.
- Choose the reference face. If you hover over the widget, a submenu displays showing different options. For more information about how to redefine the reference face, see BIMATTACHCOMPOSITION.
- Press Enter to accept the reference face.
BricsCAD responds: The composition has been assigned to <xxx> element(s).
- Select the composition in the BIM Compositions panel (
). See Dockable panels. - Hold down the left mouse button and drag the composition on the solid.
The solid face under the cursor highlights, indicating that this face is the reference face to attach the composition.
- Release the left mouse button to attach the composition.
- A widget appears that allows you to choose the reference face.The reference face is fixed, while the opposite face moves if the thickness of the composition does not fit the current thickness of the solid.
- A darker volume indicates the volume and position of the solid after attaching the composition.
- Press Enter to accept the current reference face and attach the composition.
- Select the solids you want to apply the composition to.
- Select the composition in the BIM Compositions panel.
- Hold down the left mouse button and drag the composition on any of the selected solids.
- Release the left mouse button to attach the composition.A widget appears which allows you to choose the reference face for every segment separately.
- BIM compositions are copied to the Project database upon attachment.
- Attaching a Wall composition to a solid, automatically classifies the solid as a wall.
- Attaching a Slab or Roof composition to a solid, automatically classifies the solid as a slab.
Copy compositions from other solids
- Select the Entity option.
Prompts you: Select other entity to get composition:
- Select the solid to copy the composition from.
- Select the solids(s) to attach the copied composition to.
- A widget appears which allows you to choose the reference face for every segment separately.
Removing compositions from solids
The Unclassify option of the BIMCLASSIFY command removes a composition from a solid.
- Select the solid(s).
- Choose Unclassify from the BIM command group in the Quad.
