BIM classify
Commands
BIMCLASSIFY
About
If you have a conceptual model without any classification, you can turn these elements into classified BIM elements using BIMCLASSIFY.
For more information about this command, visit the BIMCLASSIFY command article.
Classifying entities
- Select an entity in the drawing to classify.
- Choose a classification type (1) in the BIM command group in the Quad.
The BIM data is assigned to the selected entity.
- (Optional) Choose the Classify Manually option (2) from the Quad to access the BIM Element classification types. This displays the Classify As BIM Element dialog box.
Do one of the following:- Enter a specific name of the BIM Element type in the Search field (3) to filter the available element types.
- Select a Building Element type from the list.
- (Optional) Check the Convert to block and classify the block reference option (4) and enter a name in the Block name field (5).
This option will convert the selected entity to a block and classify the block reference to the defined Building Element type.
- Click the OK button to accept it.
- (Optional) Use the Auto (
) option from the Quad to classify the selected entities automatically.This automatic classification is done based on the geometrical features of the object. Always check whether it was correctly classified.
- To remove the assigned BIM data from the entity, select the entity in the drawing and choose the Unclassify (
) option from the Quad.The BIM data is removed from the selected entity.
Properties of the classified entities
When you classify an entity, a number of properties with regard to the building element type is displayed in the Properties panel.
Note: To have access to element properties but not classify an entity as a specific element type, choose the Building Element type from the Generic Elements category for the that entity.
