Parametrize details
Commands
BIMPARAMETRIZEDETAIL
About BIMPARAMETRIZEDETAIL
Use the BIMPARAMETRIZEDETAIL command to automatically generate parameters for a saved detail. Standard parameters, such as angles, offsets in different directions and tolerance parameters are created. These parameters mean you can propagate details to target situations similar to the example below.
The automatically generated parameters form a framework that can control the position and shape of the reference solids. You can extend this framework adding custom constraints. You can evaluate the effect of these changes by animating the parameters from the Mechanical Browser. You can add custom constraints to link detail objects to the reference solids and to each other. You can also use the framework parameters in the expression of those constraints.
Parametrize and edit a wall-slab connection detail
- To open the .dwg file of the detail you want to parametrize click on the detail in the Details panel. The View Detail dialog box displays.
- Click Parametrize, or click Open and run BIMPARAMETRIZEDETAIL. The detail .dwg file will open and the detail will be parametrized.
- Open the Mechanical Browser.
- Click the Mechanical Browser button in the tool panel set.
- If the Mechanical Browser button isn't visible yet, move the cursor to the toolbar or ribbon panel and right-click. A context menu displays.
Expand the Panels option.
Select Mechanical Browser in the context menu. - Once you have clicked on the Mechanical Browser button, the Mechanical Browser displays:
Note: You can also use the MECHANICALBROWSEROPEN command.(1) Group by entity: Group the parameters and constrains by entity.
(2) Group by type: Group the parameters and constrains by type.
(3) Sort: Sort alphabetically.
(4) Settings: An options menu will display:
- Expressions of constraints: Controls whether the numeric value or the assigned parameter name displays.
- Components parameters: Expressions at sub-components control the visual representation of sub-component parameters: numeric value or assigned parameter name.
- Expressions of components parameters: Sub-component parameters control the visibility of sub-component parameters.
- Sub-components of standard parts: Parameters at properties add a parameters section for the selected instance to the Mechanical Browser properties.
- Arrays of entities: Toggles the display of Array nodes in the browser tree, including Components arrays.
- Block and External references: Toggles the display of Blocks and External References nodes in the browser tree. Also toggles node building in the Bodies folder for Block entities.
- Always synchronize selection: Toggles the synchronization of the selection nodes in the Mechanical Browser with the selection of the corresponding objects in the model space. When an object is removed from a selection, only nodes corresponding to the objects remaining in the selection remain selected. If no objects are selected, the root node will be selected (similarly to when a document is open).
(5) Show search (Ctrl+F): Show or hides the search bar.
(6) The name of the parametrized detail.
(7) Parameters: Right-click on a parameter to open a context menu:- Geometry-driven: If checked, it makes the parameter geometry-driven.
- Create design table: Creates a design table to drive parametric block parameters.
- Animate: Animates models by means of parameters.
- Delete: Deletes the selected parameter.
- Renumerate similar nodes: Renumerates all nodes of the same type and the same level.
- Collapse all: Collapse the whole Mechanical Browser.
- Expand all: Expand the whole Mechanical Browser.
(8) Tolerance Parameters: The maximum and minimum variation of an angle, thickness or dimension from the original parameter value.
(9) Bodies: Display the bodies in the model.
(10) Constraints: The constraints you can delete, modify or add.
(11) Component: The properties of the detail file.
Note: Some default constraints are generated that link the detail volume and the detail objects to the reference solids. You can delete and replace them with other constraints.
- Edit the parameters.
The parameters that were generated have specific values to ensure the detail looks exactly as it was created. If you change these values, the detail will change.
For example:- Change the Thickness_Ply1_Wall_30_31 parameter from 40 to 70 (in the Expression field). The new detail is visibly different in the model space:
Before After
- Change the Angle_32_30 parameter from 90 to 120. The new angle between the wall and the slab is different in the model space.A warning pops up:
This is because the AngularTolerance parameter was set to 10. The new AngularTolerance parameter automatically changes to 30 because you changed the Angle_30_31 parameter by 30 degrees.
- Click OK
Before After
Parametrize and edit a structural steel connection
- To open the .dwg file of the detail you want to parametrize, click on the detail in the Details panel. The View Detail dialog box displays.
- Click Parametrize, or click Open and run BIMPARAMETRIZEDETAIL.The detail .dwg file will open and the detail will be parametrized.
- Open the Mechanical Browser:
Note: For connections between linear reference solids, only the framework parameters are automatically generated. You must manually add constraints to specify the behavior of detail objects in relation to the reference solids. In this example, three coincidence constraints have been manually added: two to make sure that the connection planes of the triangular steel plate maintain coincident with the flanges of the steel column and girder, and one to make sure that the end section of the girder maintains coincident with the column flange. You can add coincidence constraints before or after the parametrize tool. If you add the coincidence constraints after you can see how the reference solids change with new parameters. This makes it clear which constraints have to be added to make all detail objects move correctly. - Edit parameters.
The parameters that were generated have specific values that make sure the detail looks exactly as it was created. If you change these values, the detail will change.
For example:- Change the Angle2_Beam_2E from -28.1931013282 to -40. The column and the girder change in the model space.A warning pops up:
This is because the AngularTolerance parameter was set to 10. The AngularTolerance parameter automatically changed to 11.8069 because you have changed the Angle2_Beam_2E by 11.8069 degrees. Click OK.Before After
- Change the Offset1_Beam_2E 0 to 200. You see the girder moves 200 mm downwards. A warning pops up:
This is because the OffsetTolerance parameter was set to 31. The OffsetTolerance parameter automatically changed to 200 because you changed the Offset1_Beam_2E parameter by 200 mm. Click OK.Before After
Propagate a detail in a project
- With the Details Panel: propagate a detail from the project on all similar connections in the project.
- With the BIMPROPAGATEFROMFILE command: propagate a detail from a file.
Fewer suggestions are given by the BIMPROPAGATE command for a detail that is not parametrized. This is because a detail that is not parametrized has fewer possible locations.
For example: if a non-parametrized detail of a wall-slab connection is propagated, BricsCAD BIM won't be able to propagate this detail to a wall-slab connection when the composition is different or a particular ply in the wall differs 10 mm from the corresponding ply in the wall of the original detail. To solve this problem parametrize the detail.
The BIMPROPAGATE command can adapt a detail with parameters to situations that differ from the original (eg: another corner, a smaller profile, etc.). You can decide how much the connections can differ from the original with the tolerance parameters.
- Angular: Sets the tolerance on angle parameters of the detail in degrees. Angles in the target situation cannot deviate more than this tolerance value from the original angles in the detail.
- Dimension: Sets the tolerance for the profile dimensions of linear reference solids in the detail. Profile widths and heights in the target situation cannot deviate more than this tolerance from the original widths and heights in the detail.
- Offset: Sets the tolerance for offset parameters of the detail. Offsets in the target situation cannot deviate more than this tolerance from the original offsets in the detail.
- Thickness: Sets the tolerance for the total thickness of planar reference solids in the detail. Thicknesses in the target situation cannot deviate more than this tolerance from the original thicknesses in the detail.
