Using the Bricsys 24/7 panel
About Bricsys 24/7
The Bricsys 24/7 panel helps team members to find and share their drawings.
Bricsys 24/7 enables project management, a collaboration between project teams, cloud computing security and task automation. The big advantage of this cloud-based service is that BricsCAD is directly linked to it by the Bricsys 24/7 panel.
Use the Bricsys 24/7 panel in BricsCAD BIM
- Open the Bricsys 24/7 panel by clicking on the Bricsys 24/7 icon (
) in the Tool panel on the right side of the workspace.Note: If you do not find this icon in the Tool panel, right-click the Tool panel and check Bricsys 24/7 in the drop-down menu, as is described in the Panels article. -
Log in to your 24/7 account if necessary (see Bricsys 24/7 panel help article).
Add a file to the project
- Open a folder where you want to add the file.
- Press the plus icon that opens the Add new document and choose a file to add.
- Choose a status from the drop down list, for example Draft.
- Enter a description.
- Press the Upload button.
The file is displayed in the folder list files and it is Available for download. The folder path for files downloaded through the Bricsys 24/7 panel is defined with the CLOUDDOWNLOADPATH system variable.
The file is opened by double-clicking it.
After editing and saving it, the status of the file is changed to Locally modified.
By right-clicking the file, you can choose to lock it for editing by another person.
You can upload the modified file with a new status and description. The file will be marked as Up-to-date.
