Assembly Design Bottom-up and Top-down Assembly DesignAssembly Design Commands and ToolsMechanical block PropertiesCustom properties of mechanical blocksHow to create a custom standard partAssembly mass propertiesStandard partsPiping in Assembly DesignArrays of Mechanical blocksArray PropertiesRepresentationsBill of Materials ManagerBill of MaterialsMulti-parametric 3D animationsMechanical blocks, XRefs and 3D solidsUsing the Library panel in the Mechanical workspaceParent topic: BricsCAD Mechanical
