Drawing linear entities
Commands for drawing linear entities are:
| 3DPOLY command | Draws polylines with x,y,z coordinates. |
| ARC command | Draws arcs. |
| BOUNDARY command | Creates a polyline that forms a boundary around closed areas. |
| CIRCLE command | Draws circles. |
| DONUT command | Draws wide circles from polylines. |
| ELLIPSE command | Draws ellipses and elliptical arcs. |
| HELIX command | Draws 2D spirals or a 3D helices. |
| LINE command | Draws line segments. |
| MLINE command | Draws multilines. |
| PLINE command | Draws connected lines and arcs. |
| POLYGON command | Draws regular polygons out of polylines. |
| RAY command | Draws semi-infinite lines. |
| RECTANG command | Draws rectangles and squares. |
| REVCLOUD command | Draws revision clouds. |
| SKETCH command | Draws sketched (freehand) lines. |
| SPLINE command | Draws open and closed splines in 2D and 3D. |
| TRACE command | Draws wide line segments. |
| XLINE command | Draws infinite lines. |
