Drawing polygons
Polygons are closed polylines comprised of a minimum of three and a maximum of 1,024 equal-length sides.
You can draw polygons using the following methods:
- Center - Vertex: first define the center point, then the vertex (= radius of the circumscribed circle method).
- Center - Side: first define the center point, then the midpoint of a side (= radius of the inscribed circle method).
- Edge: define the length of the side of the polygon.
The Polygon tool is available on:
- the Draw menu
- the Draw toolbar
- the Draw ribbon panel
- the Draw tab of the No Selection Quad
General procedure
- Launch the POLYGON command.
Prompts you: Set number of sides or [Width of line/Multiple polygons] <4>:
- Do one of the following:
- Press Enter or right click to accept the current number of sides.
- Type a value, then press Enter.
Prompts you: Set center of polygon or [specify by Edge]:
- Specify a point.
Prompts you: Select midpoint of side or [specify by Vertex]:
- Specify a point.
Note:
- The option that you choose in step 3 (midpoint of side or specify by Vertex) is remembered the next time.
- The number of sides is set by the POLYSIDES system variable, but the value is not saved between sessions. The first time you launch the POLYGON command in a BricsCAD session POLYSIDES = 4.
