Drawing solids
2D Solids are rectangular, square, triangular or quadrilateral areas filled with a solid color.
Left to right: quadrilateral, rectangular, square and triangular solids
The Solid tool is available on:
  • the Draw menu
  • the Draw toolbar
  • the Draw Ribbon panel
General procedure
  1. Launch the SOLID command.
    Prompts you: Set first point of plane or [Rectangle/Square/Triangle]:
  2. Specify a point.
    Prompts you: Second point:
  3. Specify a point.
    Prompts you: Third point of plane:
  4. Specify a point.
    Prompts you: Fourth point:
  5. Specify a point.
    The solid is created.
  6. Do one of the following:
    • Keep specifying points to create more solids.
    • Right click to stop.
Note: When the FILLMODE system variable is turned off, all filled entities, such as solids, display and print as outlines.
