Drawing splines
A spline is an open or closed smooth curve defined by a set of points. You can use splines to draw curved lines, which cannot be drawn as a polyline.
The Spline tool is available on:
  • The Draw menu.
  • The Draw toolbar.
  • The Draw Ribbon panel.
  • The Draw tab of the No Selection Quad.
General procedure
  1. Launch the SPLINE command.
    Prompts you: First point of spline:
  2. Specify a point.
    Prompts you: Second point:
  3. Specify a point.
    Prompts you: Set next point or [Close/Fit tolerance/Undo]:
  4. (option) Repeat step 3 to define more points.
  5. Right click to stop adding more points.
    Prompts you: Select starting tangent point:
    A line that is tangent to the spline displays dynamically from the start point of the spline.
  6. Click to define the starting curve of the spline.
    Prompts you: Select ending tangent point:
    A line that is tangent to the spline displays dynamically from the end point of the spline.
  7. Click to create the spline.
