Fill mode
The FILL command toggles the display of filled and hatched areas and specifies whether wide polylines, traces, solids, hatches (including solid-fill) and wide polylines are filled in. It toggles the value of the FILLMODE system variable.
When FILLMODE is Off, all filled entities display and print as outlines and reduces the time it takes to display or print a drawing.
| Polyline | Donut | Trace | Plane (Solid) | |
| Fill On |   |   |   |   |
| Fill Off |   |   |   |   |
Setting Fill Mode
Do one of the following:
- Run the FILL command.
- Set the value of the FILLMODE system variable.
Run the REGEN or REGENALL command to regenerate the viewport(s).
