Creating diametrical and radial dimensions
The DIMCENTER and DIMDIAMETER commands create diametrical and radial dimensions to annotate the radii and diameters of circles and circular arcs.
To create a diametrical dimension
- Launch the DIMDIAMETER command.
You are prompted: Select arc or circle to dimension [selection options (?)]:
- Select an arc or a circle.
The diametrical dimension is dynamically displayed.
- Specify a point to position the dimension entity.
To create a radial dimension
- Launch the DIMRADIUS command.
The radial dimension is dynamically displayed.
