Dimension settings
Dimension settings are saved in a dimension style. Dimension entities are created using the settings in the current dimension style.
The DIMSTYLE command creates and modifies dimension styles, through the Drawing Explorer.
The -DIMSTYLE command creates and modifies dimension styles at the Command line.
A dimension style consists of six settings groups
- Lines and Arrows
- Text
- Fit
- Primary Units
- Alternate Units
- Tolerances
To list the current status of the dimension variables
- Do one of the following:
- Click the Dimension Variable Status tool button (
) on the Dimensions toolbar. -
- Choose Dimension Variable Status in the Dimensions menu.
A list of all dimension variables displays in the Command line.
- Press the F2 function key to open the BricsCAD Prompt History window.
- Press Enter to continue the listing.
- Press the F2 function key to close the BricsCAD Prompt History window.
