Managing Xrefs
The EXPXREFS command opens the External References section of the Drawing Explorer dialog box.
The XREF command opens the Attachments panel.
The Drawing Explorer - External References dialog box allows you to:
- Attach a drawing as an external reference (
). - Detach an external reference (
). - Reload an external reference (
). - Unload an external reference (
). - Bind an external reference (
). - Insert an external reference (
). - Modify the attachment type: Attach or Overlay.
 - Modify the Saved Path of an Xref.
 - Modify the Found Path of an overlay.
To detach external references
- Select the Xref(s) you want to detach.
Press and hold the Ctrl key to select multiple Xrefs or to unselect a selected Xref.
 - Click the Detach Xref tool button (
) on the Details toolbar.The selected Xref(s) are detached. You are not prompted to confirm the detachment.
To unload external references
Do one of the following:
- Click the Loaded column of a loaded Xref.
 - Select the Xref(s), then either click the Unload Xref tool button (
) on the Details toolbar or click the Loaded column of one of the selected Xrefs.
To reload external references
- Click the Loaded column of an unloaded Xref.
 - Select the Xref(s), then either click the Reload Xref tool button (
