Editing block attributes
Block attributes can be edited in the Properties panel.
- Select a block containing attributes.
The current value of the attributes is displayed in the Properties panel.
- Select the attribute you want to edit.
The settings field of the selected attribute is active.
- Type a new value, then press enter or select another attribute.
