Creating menus
Main menus sit in the menu bar at the top of the BricsCAD application window. Submenus show as a flyout of a main menu.
The MENUBAR system variable controls the display of menus.
Creating a main menu
- In the Customize dialog, click the Menus tab.
- Do one of the following:
- Click the Main Menus subgroup of a menu group, then right-click and choose Append main menu in the context menu.
The new menu will be added below the last existing menu.
- Select an existing menu in the Main Menus subgroup, then right-click and choose Insert main menu in the context menu.
The new menu will be added above the selected menu.
The Add Main Menu dialog box appears.
- Type a name in the Title.
- Click the OK button.
The main menu is created.
- Add items to the menu.
Note: The new main menu is not visible in the menu bar until at least one menu item is added to it.
Adding a submenu to a main menu
If collapsed, expand the menu group.
If collapsed, expand the Main menus group of the menu group.
- Select a main menu, then right-click and choose Append submenu in the context menu.
The new submenu will be added below the last existing submenu.
- Select an existing submenu, then right-click and choose Insert submenu in the context menu.
The new submenu will be added above the selected submenu.
The Add submenu dialog box appears.
- Type a name in the Title field.
The submenu is created.
- Add items to the submenu.
Adding a submenu to a submenu
- Expand the submenu.
- Select an item in the submenu, then right-click and choose Insert submenu in the context menu.
