Loading and unloading CUI files
When you install BricsCAD, the default CUI file is copied to the Support folder (see the BricsCAD User Files article).
There are two procedures to load a CUI file:
- Load main CUI file: replaces the currently loaded main CUI file.
- Load partial CUI file: adds custom customizations to the interface.
When you launch BricsCAD after installing a major update, you have the option to copy the files and settings from the previous BricsCAD installation, preserving user changes in the CUI while adding the new CUI components.
Loading a main CUI file
- Launch the CUSTOMIZE command.
The Customize dialog box appears.
- In the File menu, choose Load main CUI file....
The Select main CUI file dialog box displays the content of the Support folder.
- Select a CUI file, then double-click or click the Open button.
The selected CUI file is loaded.
- Close the Customize dialog box.
Loading a partial CUI file
- In the File menu, choose Load partial CUI file....
The Choose a customization file dialog box displays the content of the Support folder.
The content of the selected CUI file is appended: definitions which are different from the ones in the main CUI are used.
In case of a CUI load error
In the case of a load error due to a corrupted CUI file, an error message is displayed allowing you to try restoring from the latest backup, or using a CUI file with the same name from the UserDataCache, if any.
Unloading a partial CUI file
- Click the Menus tab.
- Right-click the partial CUI name and choose Unload <PartialCuiName> in the context menu.
Managing customization groups
- Launch the MENULOAD command.
The Customization groups dialog box opens.
- (Optional) To load a partial CUI file, click the browse button (
) to select a partial CUI file, then click the Load button. - (Optional) To unload a partial CUI file, select the partial CUI file in the Loaded Customization Groups list, then click the Unload button.
- Click the Close button to stop.
