Managing toolboxes
A toolbox contains a set of tools, which can be added to menus, toolbars, ribbon panels, Quad tabs and keyboard or mouse shortcuts. Toolboxes can be created in the main CUI or in a partial CUI.
Creating a toolbox in a menu group
- In the Customize dialog box, select a menu group in the Available Tools panel:
- BricsCAD (= default main CUI)
- <PartialCuiName> (= partial CUI)
- Right-click and choose Append toolbox in the context menu.
The Add Toolbox dialog box appears.
- Type a name for the new toolbox in the Name field, then click the OK button.
The toolbox is added in the Available Tools tree.
Creating a tool in a toolbox
- In the Customize dialog box, select a toolbox in the Available Tools panel.
- Right-click and choose Append tool in the context menu.
The Add tool dialog box appears.
- Title: type a name for the new tool.
- Help: type a help string.
- Command: type a command or a command macro*.
- Image: Click the Browse button (
).The Tool Image dialog box appears.
- Do one of the following:
- Select Builtin, then choose one of the built-in icons.
- Select Bitmap file, first choose to select one image file or a small and a large image file, then click the Browse button (
) to select the image file(s).
- Click the OK button to create the tool.
* Syntax to create command macros:
- Start the macro with ^c^c, the equivalent of pressing the Esc key twice, which first ends a running command if necessary.
- Type an underscore (_) in front of a command name if you want to use the macro in a non-English version of BRICSCAD.
- A period (.) in front of a command name ensures that the macro still works if this command is temporarily undefined.
- A minus sign (-) in front of a command launches the Command line version of a command, thus preventing the command dialog window to open.
- A semicolon (;) is the equivalent of pressing the Enter key, e.g. to accept a default prompt option.
- A backslash (\) temporarily pauses the macro to allow user input, e.g. specifying a point.
In the following macro: ^c^c_-layer;m;InteriorWalls;;_mline
- ^c^c concludes a running command, if any.
- layer; launches the -LAYER command.
- m; selects the Make new current layer option.
- InteriorWalls makes the InteriorWalls layer current and creates it first if necessary.
- ;;_mline concludes the -LAYER command and launches the MLINE command.
