Add scale dialog box
The Add Scale dialog box allows you to add a new scale factor to the list.
  1. Scale name
  2. Scale properties
Scale name
Specifies the scale name as it will appear in the scale list.
Scale properties
Specifies the scale factor in paper (size when plotted) and drawing units.
Parent topic: BricsCAD
Parent topic: Dialog boxes
Related commands
  • OBJECTSCALE command
  • -OBJECTSCALE command
  • PAGESETUP command
  • PRINT command
  • SCALELISTEDIT command
  • -SCALELISTEDIT command
