Block Replace dialog box
The Block Replace dialog box allows you to replace specific block instances with other blocks. It is opened with the BLOCKREPLACE command.
- Select the block to be replaced.
- Select particular block instances.
- Options.
- Select the block to replace selected block instances.
- Choose a .dwg or a .dxf file instead of a block name.
- Select a block by clicking on it.
- The blockName.
Selects a block by name to be replaced.
Note: The modified (anonymous) dynamic blocks cannot be selected by name.
Selects any block instances, including modified (anonymous) dynamic block instances to be replaced.
Options
- Replace similar inserts
- Replaces all modified (anonymous) and unmodified instances of dynamic block and all instances of non-dynamic block selected.
- Keep parametric block expressions
- Keeps the parameters' expressions of the old block if the replacement block has parameters with identical names.
- Purge unreferenced block
- Removes unreferenced block instances.
- Select the block to replace selected block instances by
- Choosing a block name from the list.
- (5) Browsing for a .dwg or a .dxf file (the file name will be the block name).
- (6) Selecting a block by clicking on it.
- (7) Typing a file name of an external .dwg or .dxf that will be used as a new block name (e.g. fileName.dwg) or typing "blockName=fileName.dwg" when the new block name should be different than the file name.Note: fileName.dwg can have blocks with the same names as in the current drawing. In this case, blocks from the file do not re-define blocks with the same names already present in the current drawing.Note: If fileName.dwg file is not located in the support file search path, you have to indicate the complete path.
