Import Sheet Set dialog box
The Import Sheet Set dialog box allows you to import a sheet set file that has been created using the Export Sheet Set As dialog box.
- XML File path
- Select XML File
- Save Sheet Set As
- DST File path
- Save Sheet Set As
XML File path
Displays the path of the *.xml file after selecting it using the Select XML File button.
Note: A warning message appears when trying to import a sheet layout which already exist in a sheet set.
Select XML File
Opens the Select XML File dialog box.
Save Sheet Set As
Choose how to save the imported XML file as DST file using:
- Same location and name as XML file (but DST extension).
- Another location or name. Clicking this button, will open the Save Sheet Set As dialog box.
DST File path
Displays the DST file path and name.
Save Sheet Set As
Opens the Save Sheet Set As dialog box. This button is active only when saving the sheet set in another location or name than the XML imported file.
