Select Custom Arrow Block dialog box
Opens via: Qleader Settings dialog box > Select arrow option
The Select Custom Arrow Block dialog box allows you to choose a block to define the shape of the arrowhead.
- Select from Drawing Blocks
Specifies one of the blocks in the drawing to use as arrowhead.
