Upload to Bricsys 24/7 dialog box
The Upload to Bricsys 24/7 dialog box allows you to upload packages of drawing files and it dependencies to Bricsys 24/7
Note: The project needs to be saved before uploading it to Bricsys 24/7.
![](https://static.bricsys.com/help/images/V23/en_US/DB_Upload_to_bricsys_247_02.png)
- Root drawing
- Font files
- Font map files
- Other
- Select/deselect all font files
Root drawing
Displays a list of the current drawing files.
Font files
Displays a list of the currently used font files.
Font map files
Displays a list of the currently used font map files.
Other
Displays a list of other used files such as render material images.
When checked, all font files and font map files are checked if this was not the case before. When unchecked, all font files are unchecked if there were any checked before. Pressing the Continue button will ask you to sign in Bricsys 24/7 to complete the uploading process.
