BricsCAD and AutoCAD feature comparison
The following tables compare BricsCAD features with AutoCAD® features.
Drawings
BricsCAD AutoCAD®
Lite Pro BIM Mechanical Ultimate LT Full
Native DWG file format (thru AutoCAD® 2025)
DWG Password Protection - -
eTransmit
Sheet Set Manager
Geographic Location Settings
Bing and Esri Maps
Note: BricsCAD provides Bing and Esri Maps through the GEOMAP command.
Drawing Compare
Cloud Collaboration
Interface
BricsCAD AutoCAD®
Dark and Light Color Themes
Industry standard commands, aliases, and variables
Clickable Command Line with Auto Complete
Start page
File (Drawing) tabs
Model and Layout tabs
Layout Manager - -
Menu Bar
Toolbars
Ribbon
Tool Palettes
Contextual Right-click Menus
Contextual Quad Menu - -
Status Bar
Workspaces
Searchable Settings (SysVar) Dialog Box - -
Lockable Interface
Clean Screen Mode
Drawing Explorer - -
Customizable User Interface (CUI)
Structure panel - -
Selection, snap & track
BricsCAD AutoCAD®
Selection Filtering (QSELECT)
Add Selected
Select Similar
Selection Cycling
Entity Snaps (OSNAPs)
Polar Tracking
Z-intersection 3D snap - -
Nearest Distance - -
Adaptive Grid Snap - -
Real-time Boundary Detection - -
2D Dynamic UCS - -
3D Dynamic UCS -
Drawing tools
BricsCAD AutoCAD®
Line, Polyline, 3D Polyline, Spline, Ray, Xline
Multi-lines and Multi-line Styles -
Circle, Arc, Ellipse, Elliptical Arc
Polygon, Rectangle, Region, Donut, Point
Helix -
2D Parameters & Constraints -
2D Auto-constrain 1 1
Calculator
Annotation tools
BricsCAD AutoCAD®
Dimensions, Dimension Styles
Quick Dimension
Multi-leaders, Multi-leader Styles
Single and Multi-line text, Text Styles, Text Editor
Hatches, Gradients, Hatch/Gradient Editor
Wipeouts
Revision Clouds
Attributes, Attribute Editor
Tables, Table Styles
Fields
Data Extraction -
Data Linking
Annotation Scaling
Spell Check
AutoCAD® Mechanical Compatibility: Read, Display, Edit, Create - - - 2 2 - -
Editing tools
BricsCAD AutoCAD®
Move, Copy, Rotate, Scale, Stretch, Mirror, Align
Trim, Extend, Lengthen, Break, Join
Fillet, Chamfer
CopyGuided - -
MoveGuided - -
Grip Editing
Properties panel
Manipulator (3D Gizmo) -
Draw Order
Undo Per Entity (Property History) - -
Optimize - -
Simplify - -
Drawing Health Management - -
Reference tools
BricsCAD AutoCAD®
Blocks, Block Editor
Dynamic Blocks 3 3 3 3 3
Camera-facing Blocks - -
Blockify 4 4
Associative Arrays
DWG (XREF) Attach, Clip, Bind, & Edit
PDF Attach, & Clip
Image Attach, Clip, & Adjust, with Transparency
Point Cloud Color-mapping - -
Visualization tools
BricsCAD AutoCAD®
Layers & Layer States
Entity Transparency
Visual Styles -
LookFrom (ViewCube) -
Match Perspective - -
Lights - -
Sun Properties - -
Materials - -
Rendering - -
Animation Editor - - -
Walk-through 3D Navigation - -
ANIPATH command - -
Built-in Datasmith Export - - -
Built-in Direct Link with Twinmotion/Unreal - - -
Modeling tools
BricsCAD AutoCAD®
ACIS-based Solid Modeling - -
Solid and Surface Modeling - -
Solid Primitives - -
Mesh Primitives - -
Polysolids - -
Union, Subtract, Intersect, Interfere - -
Extrude, Revolve, Loft, Sweep, Thicken - -
Twist - - -
Fillet, Chamfer - -
Slice - -
Multi-slice - - -
T-Connect, L-Connect, & Connect with Nearest Tools - - -
Extract Edges - -
Direct (history-less) Modeling - -
Deformable (Free-form) Modeling - -
Audit, Simplify -
Solidify - -
Stitch - -
3D Parameters & Constraints - -
3D Automatic Parameterization - - -
3D Blockify and Parametric Blockify - - -
3D Parametric Design Tables - - -
Section Planes - -
Drawing Views: Base, Projected, Section, Detail and Break Views - -
3D Threads - - -
Point Cloud Align - - -
Point Cloud Bubble Viewer (static and kinematic scans) - -
Civil and Survey tools
BricsCAD AutoCAD®
TIN Surface Modeling - - -
Civil Points - - -
TIN Volume Surface - - -
Grading - - -
Alignments - - -
Strings - - -
Profiles (Vertical Alignments) - - -
Corridors - - -
Autodesk® Civil 3D Object Enabler -
Boundary Trim - - -
GIS Data - - -
Labels - - -
Building tools
BricsCAD AutoCAD®
CAD-based BIM features - - - - -
IFC Import/Export - - - - -
IDS Import - - - - -
RVT/RFA Import - - - - -
RVT Export - - - - -
Structural Modeling Toolset - - - - -
Project Database - - - - -
Model federation reference points (Survey, Project, and Site Location) - - - - -
Project Browser - - - - -
Library Database - - - - -
Site, Building and Stories - - - - -
Windows and Doors - - - - -
Fully Parametric BIM Component Creation - - - - -
Bill of Materials (BOM) Manager - - - -
3D Spaces - - - - -
Wall - - - - -
Roof - - - - -
Quickdraw - - - - -
Quickbuilding - - - - -
Point Cloud Classifier - - -
Point Cloud Floor Detection - - - - -
Point Cloud Projection - - - - -
Point Cloud Geometry Detection - - - - -
Point Cloud FitPlanar (geometry detection) - - - - -
Point Cloud Room Detection - - - - -
Point Cloud FitRooms - - - - -
Point Cloud Dollhouse - -
POINTCLOUDGAPFILLING - -
POINTCLOUDSHOWBUBBLES - -
POINTCLOUDEYEDOMELIGHTING - -
Construction Detail Management - - - - -
Propagate - - - - -
Custom BIM Properties - - - - -
Graphical Override - - - - -
Drawing Customizations - - - - -
BIM Dimensions - - - - -
Selection Dimensions - - - - -
Analytical Models - - - - -
Python Scripts (Beta) - - - - -
BCF issue management - - - - -
Manufacturing tools
BricsCAD AutoCAD®
AutoCAD® Mechanical 2021 DWG file format - - - -
Support for 2D Mechanical Drawing Standards  (ISO, DIN, JIS, ANSI) - - - -
Parts Reference and Part Lists - - - -
Balloons associated with Part References - - - -
Power dimensions - - - -
Welding Symbols - - - -
Surface Texture - - - -
Feature Control Frame - - - -
Datum ID - - - -
Edge Symbol - - - -
Taper and Slope Symbols - - - -
Leader Notes - - - -
Rescale Annotations - - - -
Mechanical Browser - - -
Parts Library - -
Piping - - -
Assembly Modeling - - - - -
Assembly Inspect - - - - -
Exploded Views - - - - -
Kinematic Analysis - - - - -
Bill of Materials (BOM) - - - - -
Balloons associated with BOM and Drawing Views - - - - -
Sheet Metal Design - - - - -
3D Solids to Sheet Metal Parts Recognition and Conversion - - - - -
Corner Relief for Adjacent Edge Flanges - - - - -
Lofted Bends - - - - -
Other features: Junctions, Miters, Tabs, Form Features - - - - -
Feature Coloring - - - - -
Diagnostic & Repair for Sheet Metal Features - - - - -
Batch Processing of Sheet Metal Features - - - - -
Import, export, output
BricsCAD AutoCAD®
Print/Plot
Print as JPG
Print as TIFF
Print as PNG
Print as BMP
Publish/Batch Plot
Create PDF Bookmarks
CTB & STB Files
PC3 Printer Configuration Files
Named Page Setups
PDF Import, Export
DAE Import, Export - -
IFC Import, Export - - - -
3DM Import, Export - - -
LandXML Import, Export - - -
Import Autodesk® Civil 3D Data - - -
SKP Import - - -
DGN Import
RVT Import, Export - - - - -
DWF Export
SVG Export - -
FBX Export - -
STL Export -
Point Cloud Export (available formats below) - - 5
LAZ - - 5
HSPC - - 5
PTS - - 5
Point Cloud Import (available formats below) - - 5
e57 - - 5
HSPC - - -
LAS - - 5
LAZ - - 5
LGSX - - -
HSPC.PACK - - -
PTS - - 5
PTX - - 5
RCP - -
RCS - -
RSP - - 5
RDBX - - 5
ZFS - - 5
Additional file formats accessible via Communicator for BricsCAD (available formats below)
CATIA V4 4.1.9 − 4.2.4 - -
CATIA V5 V5R8 − V5−6 R2021 - -
IGES up to 5.3 - -
Inventor V11 − V2022 - -
JT 8.x, 9.x, 10, 10.2, 10.3, and 10.5 - -
NX 1 − NX 195311 − NX 1953 - -
Parasolid 9.0.x − 33.0.x - -
Pro/E / Creo 16 − Creo 8.0 - -
Solid Edge V18 − SE 2021 - - -
SolidWorks 2003 − 2021 - -
STEP AP203, AP214, AP242 - -
STL All (Graphical data only) - - -
VDA−FS 1.0 − 2.0 - - -
XCGM R2012 − 2021 1.0 - - -
Programming
BricsCAD AutoCAD®
ActiveX
Extended Entity Data Editor -
Script Recorder -
Full LISP Support (vl, vlr, vla and vlax)
Solutions Development System (SDS/ADS) -
Dialog Control Language (DCL)
COM API -
VBA Project Support - -
.NET Framework API - - -
.NET Core API - - - - - -
BRX (ARX-compatible API) - -
TX (Teigha eXtensions) - -
CUI Menu File Support, with Diesel Expressions
Licensing
BricsCAD AutoCAD®
Cross-platform Licenses (Windows, Linux, macOS) - -
Perpetual Licenses - -
Perpetual + (Optional) Maintenance (6) - -
Subscriptions (7)
Network Multi-user - -
Volume (Perpetual) - -
Academic
(1) You can automatically apply geometric constraints but you cannot automatically apply a combination of geometric and dimensional constraints.
(2) You can create ACM symbols using the following commands: AMSURFSYM, AMEDGESYM, AMWELDSYM, AMSIMPLEWELD, AMNOTE, AMFCFRAME, AMDATUMID, AMPARTLIST, AMPARTREF, AMRESCALE.
(3) You can manipulate Dynamic block insertions but you cannot create Dynamic block definitions. You can convert some Dynamic blocks to Parametric blocks that can be further edited. You can also create new Parametric block definitions.
(4) AutoCAD® has the Smart Blocks functionality.
(5) In the Autodesk® product suite, Recap is needed to import non-native point cloud formats and convert to AutoCAD®'s native RCS/RCP. For LAS/LAZ/PTS/PTX, Map 3D and/or Civil 3D may be sufficient.
(6) For Perpetual license, Maintenance is included for every new license in the first year. From the second year onwards, you are free to renew your Maintenance.
(7) For Subscriptions, Maintenance is always included during the subscription period.
