Detailed settings for the Quad cursor
This article contains the detailed setting for Quad cursor.
To see how to start working with the Quad cursor, see the article The Quad cursor menu.
Editing the Quad settings
Right click the QUAD field in the Status bar, then choose Settings in the context menu. The Settings dialog box opens, showing the Quad settings.
- Quad display
- Quad default command launch
- Quad popup corner
- Quad width
- Quad most recent items
- Quad icon size
- Quad icon space
- Quad show delay
- Quad hide delay
- Quad hide margin
- Quad go transparent
- Quad expand delay
- Quad expand tab delay
- Quad tab flags
- Property units
- Rollover tips
- Rollover opacity
- Rollover selection set
- Rollover parameters
- Selection preview display
- Shortcut menus
- Shortcut menu duration
- Tooltips
- Tooltip delay
Quad display
Determines when the Quad displays.
- Negative: Switches the Quad off.
- 1: When the cursor is over an entity. The entity under the cursor highlights.
- 2: When entities are selected.
- 4: On right click when no entities are selected and there is no entity under the cursor.
- 8: Suppress the Quad when hovering over entities that are not in the current selection set.
Activates launching the default quad command without requiring clicking the button.
- 0: The user must click the button.
- 1: The default command is launched by right clicking the entity.
Quad popup corner
Controls the popup position of the Quad relative to the cursor position: Upper right, Middle right or Lower right.
Quad width
Defines the number of columns in a row. By default, this number is 6.
Defines the number of the most recent items (entities or operations) that are displayed in the menu.
Quad icon size
Sets the size of the buttons in the menu.
- [0] = Small buttons (16 x 16 pixels).
- [1] = Large buttons (32 x 32 pixels).
- [2] = Extra-large buttons (64 x 64 pixels).
Quad icon space
Defines the space around the Quad buttons: narrow, normal or large.
Quad show delay
Sets the time interval, in milliseconds, between the highlighting of the entity and the Quad display.
Quad hide delay
Sets the time interval, in milliseconds, to keep the Quad visible after the cursor is outside the Quad hide margin limit.
Quad hide margin
Sets the distance, in pixels, where the cursor can move away from the Quad and keep it visible. If the cursor moves outside this limit, the Quad is hidden.
Quad go transparent
Defines whether the Quad becomes transparent when the mouse moves outside the Quad, but within the Quad hide margin.
Quad expand delay
Sets the time interval, in milliseconds, to expand the Quad after mouse-enter.
Sets the time interval, in milliseconds, to expand a group tab after mouse-enter.
Quad tab flags
Sets some display properties of the Quad tabs.
- 1 - Fixed with tabs: the tabs will be displayed with the same width as the buttons above them
- 2 - Center tab labels: the labels of the tabs will be displayed center aligned
- 4 - Tab borders: the tabs will display a border between them
- 8 - Double tab height: the tabs will have two rows, allowing for the display of longer labels
- 16 - Show 3D Solid mass properties: displays the mass properties for 3d Solid entities.
Property units
Displays the units for entity properties.
- 1: length properties
- 2: area properties
- 4: volume properties
- 16: dynamic dimensions
- 32: mass properties
The units displayed are those set in the drawing properties. See the UNITS command.
Rollover tips
Specifies whether entity properties display in the Quad while hovering. See the ROLLOVERTIPS system variable.
Rollover opacity
Specifies the degree of opacity when the Quad is in rollover state. Values between 10 (very transparent) and 100 (fully opaque) are accepted.
Controls the content of rollover tips when multiple entities are selected.
Rollover parameters
Shows block parameters in the rollover tips.
Controls in which cases objects are highlighted when the pick box cursor hovers over them.
- 1: when no commands are active
- 2: when a command prompts for entity selection
- The Display the Quad when the cursor hovers on an entity option of the QUADDISPLAY system variable is ignored and the Quad is not displayed.
- The ROLLOVERTIPS system variable is ignored and entity properties are not displayed (the Quad is not displayed).
- The SELECTIONCYCLING system variable is ignored and no badge or selection dialog box is displayed (the Quad is not displayed).
Shortcut menus
Controls the status of the DEFAULT, EDIT and COMMAND shortcut menus. The value is stored as a bit code using the sum of the values of all selected options.
- 1: Enable Default shortcut menus.
- 2: Enable Edit mode shortcut menus.
- 4: Enable Command mode shortcut menus (available whenever a command is active).
- 8: Enable Command mode shortcut menus only when command options are currently available from the command line.
- 16: Enable display of a shortcut menu when the right button on the pointing device is held down longer.
- 32: Repeat command with a short right click when entities are selected, and Quad is not shown.
Specifies how long the right button on a pointing device must be pressed to display a shortcut menu.
Tooltips
Turns on or off the display of tooltips for buttons, tabs and menus.
Tooltip delay
Sets the delay time, in milliseconds, to display tooltips. If the value is negative, no tooltips display.
