Document tabs
For each currently open drawing, a document tab is located on top of the drawing area.
Document Tabs allow you to:
  • Easily switch between all open drawings.
  • Create a new drawing: click the + button on the right of the tabs.
  • Close a drawing: click the X in the document tab.
Note:
  • The SHOWDOCTABS system variable needs to be On to display the Document Tabs (On by default).
  • When opening a DWG file via double click from the operating system's file browser, the Start tab is loaded in Document Tabs if the STARTUP system variable is set to 2 or 3.
