Keyboard shortcuts
Keyboard shortcuts can be a great performance enhancer, especially when toggling settings.
The following keyboard shortcuts are available:
Keyboard Description
F1
Opens the BricsCAD Help.
Executes the HELP command.
F2
Toggles the display of the Prompt History window.
See the GRAPHSCR command.
F3
Toggles the entity snaps ON/OFF.
See the OSMODE setting.
F4
Toggles the 3D entity snaps ON/OFF.
See the 3DOSMODE setting.
F5
Sets the isometric plane; toggles the value of the SNAPISOPAIR setting.
Applies only when the SNAPSTYL setting = 1.
F6 Toggles the Dynamic UCS feature.
F7 Toggles the display of the grid (see the GRIDMODE setting).
F8
Toggles the ORTHOMODE setting ON/OFF.
Disables bitcode 8 of the AUTOSNAP setting, if set.
F9 Toggles Snap ON/OFF (see the SNAP command).
F10
Toggles the Polar Tracking setting. Sets the ORTHOMODE setting OFF, if ON.
Toggles bitcode 8 of the AUTOSNAP setting ON/OFF.
F11
Toggles the Entity Snap Tracking setting.
Toggles bitcode 16 of the AUTOSNAP setting ON/OFF.
F12
Toggles the display of the Quad cursor menu.
See the QUADDISPLAY setting.
Alt + F8 Launches the VBARUN command.
Alt + F11 Launches the VBAIDE command.
Ctrl + 1
Note: Do not use the numeric keypad. On AZERTY keyboards: do not use the Shift key when pressing the number key.
Toggles the Properties panel.
Ctrl + 2
Opens the Drawing Explorer dialog box.
Ctrl + 9
Toggles the display of the Command line.
Executes the COMMANDLINE command or the COMMANDLINEHIDE command.
Ctrl + 0
Toggles the display of user interface entities as specified by the CLEANSCREENOPTIONS setting.
Executes the CLEANSCREENON command or the CLEANSCREENOFF command.
Ctrl + A Selects all entities.
Ctrl + B Toggles Snap ON/OFF (see the SNAP command).
Ctrl + C Copies the selection to the clipboard (COPYCLIP command).
Ctrl + Shift + C Copies the selection along with a base point (COPYBASE command).
Ctrl + E
Sets the isometric plane; iterates the value of the SNAPISOPAIR setting.
Ctrl + F Launches the FIND command.
Ctrl+Cmd+F Toggles the fullscreen mode.
Note: This is a macOS only shortcut.
Ctrl + G Toggles the display of the grid (GRIDMODE setting).
Ctrl + H Toggles the value of the PICKSTYLE setting, which controls the selection of groups and associative hatches.
Ctrl + I Sets the readout of the coordinate field in the Status bar (COORDS setting).
Ctrl + J Repeats the previously issued command.
Ctrl + K Attach a hyperlink to an object or modify an existing hyperlink (HYPERLINK command).
Ctrl + L Toggles the ORTHO setting.
Ctrl + M Repeats the previously issued command.
Ctrl + N Creates a new drawing (NEW command).
Ctrl + O Opens an existing drawing (OPEN command).
Ctrl + P Prints the current drawing (PRINT command).
Ctrl + Shift + P Toggles the display of the Properties panel (PROPERTIES command and PROPERTIESCLOSE command).
Ctrl + Q Quits the application; prompts to save changes (QUIT command).
Ctrl + R Iterates through viewports.
Ctrl + S Saves the current drawing (QSAVE command).
Ctrl + T Turns the tablet on/off (TABLET command).
Ctrl + Tab Shows the next document tab.
Ctrl + Shift + Tab Shows the previous document tab.
Ctrl + V Pastes the contents of the Clipboard. (PASTECLIP command).
Ctrl + Alt + V Pastes the contents of the Clipboard in a specified format (PASTESPEC command).
Ctrl + Shift + V Pastes the contents of the Clipboard as a block (PASTEBLOCK command).
Ctrl + X Cuts the selection and puts it on the clipboard (CUTCLIP command).
Ctrl + Y Redoes the last action undone (REDO command).
Ctrl + Z Undoes the last action (UNDO command).
Ctrl + [ Cancels the running command.
Ctrl + \ Cancels the running command.
Ctrl + Home Creates or opens the Start page (GOTOSTART command).
Shift + F2 Toggles the display of the Command line (COMMANDLINE command and COMMANDLINEHIDE command).
Shift + F3 Turns the Status bar on/off (STATBAR command).
Shift + F4 Turns the Scroll Bars on/off (SCROLLBAR command).
Shift + F8 Launches the Visual Basic Project Manager (VBAMAN command).
Shift + F11 Launches the VBA COM Add-In Manager (ADDINMAN command).
PgUp Moves the view up.
PgDn Moves the view down.
Shift + Left Arrow Moves the view to the left.
Shift + Right Arrow Moves the view to the right.
Shift + Up Arrow Moves the view up. If (sub)entities are selected, the entities are nudged up (along the z-axis).
Shift + Down Arrow Moves the view down. If (sub)entities are selected, the entities are nudged down (along the z-axis).
Ctrl + Left Arrow Nudges the selected (sub)entities to the left (along the x-axis).
Ctrl + Right Arrow Nudges the selected (sub)entities to the right (along the x-axis).
Ctrl + Up Arrow Nudges the selected (sub)entities up (along the y-axis).
Ctrl + Down Arrow Nudges the selected (sub)entities down (along the y-axis).
Tab
Navigates down into the autocomplete command list.
Note: This is a cross-platform shortcut.
Tab + Shift
Navigates up into the autocomplete command list.
Ctrl + N
Ctrl + P
