Prompt menus
When executing a command, BricsCAD prompts you in the Command line or the Status bar. Optionally, command options are also available in a prompt menu.
Whether prompt menus are displayed and where they are located is controlled through the PROMPTMENU system variable.
The PROMPTMENUFLAGS system variable controls the content and behavior of prompt menus.
