Launching BricsCAD
BricsCAD Launcher
If the GETSTARTED system variable is ON, the BricsCAD Launcher dialog box displays when you launch BricsCAD. Here you can choose the Workspace for the current session. The available workspaces depend on the license level.
- 2D Drafting: launches the classic Drafting workspace. BricsCAD Lite license or higher is required.
- 2D Drafting (Modern): launches the modern Drafting workspace. BricsCAD Lite license or higher is required.
- Modeling: launches the Modeling workspace. BricsCAD Pro license or higher is required.
- Civil Survey: launches the Civil workspace. BricsCAD Pro license or higher is required.
- BIM: launches the BIM workspace. BricsCAD BIM or BricsCAD Ultimate license is required.
- Mechanical: launches the Mechanical workspace. BricsCAD Mechanical or BricsCAD Ultimate license is required.
- Ultimate: launches the Utimate workspace. BricsCAD Ultimate license is required.
- Don't show this dialog again: sets the GETSTARTED system variable to 0. To reset the display of the BricsCAD Launcher dialog box, type getstarted in the Command line and choose 1 for ON.Note: The BricsCAD Launcher cannot be disabled in Trial versions.
