Complete guide to migrating custom files from AutoCAD to BricsCAD
1. Overview of custom files to migrate and their paths
Migrating custom files from AutoCAD® to BricsCAD allows the same customized working environment to be used in BricsCAD. This guide describes how to migrate each type of custom file.
Just like AutoCAD®, BricsCAD uses a variety of files that store your personal settings, customizations, profiles, and application data to assist you in creating your drawings.
The following table lists the types of custom files that can be migrated, their file extensions, and the default locations where BricsCAD stores them on each operating system.
| File type | Extension | Found in | Path | |
| Partial customization files |
Support folder |
| Linetypes | LIN | |||
| Hatch patterns | PAT | |||
| Tool palettes |
| Command aliases | PGP | |||
| Shape files | SHP | |||
| Drawing templates | DWT | Templates folder |
| Plot files | Plot Styles |
PlotStyles folder |
| Plot Config |
PlotConfig folder |
| LISP files | LSP | Support folder |
- Use the SETTINGS command to configure how BricsCAD locates and loads custom files. In the Settings dialog box, you can define all support file paths, including folders for linetypes, shapes, fonts, Xrefs, plotters and other resources required during migration.
- Use the CUSTOMIZE command to modify how the BricsCAD user interface behaves. In the Customize dialog box, you can change the actions of interface elements such as menus, Ribbons, toolbars and mouse buttons, ensuring that migrated custom files are properly integrated into your workspace.
2. Migrating custom files
Use the manual migration method to transfer specific customization resources from AutoCAD®. This method involves locating, copying, and loading individual customization files into the current BricsCAD installation.
2.1 Migrating partial customization files
CUI or CUIX files can load and save full or partial custom workspaces. Only partial customization files should be migrated. Loading a partial CUI file adds custom menus, toolbars, Ribbon elements, and other interface customizations to the existing user interface. When you install BricsCAD, the default CUI file is copied to the Support folder.
- A CUIX file is a zipped package that contains all files required by the user interface. When loaded, it is automatically converted to a CUI file. Bitmap resources contained in a CUIX file are copied to a .RESZ resource file, which can be used as an alternative to a resource DLL. Supported image formats include BMP, JPG, PNG, ICO, GIF, TIFF, XBM, and XPM.
- When migrating a partial customization file, make sure that any referenced support files, custom icons, scripts and LISP routines are also transferred and that their file paths are correctly configured in BricsCAD.
Go to AutoCAD® and launch the CUSTOMIZE command. On the Transfer tab, select the desired partial CUI file from the drop-down list and save it.
Then, go to BricsCAD and launch the CUSTOMIZE command to open the Customize dialog box. From the File menu, choose Load partial CUI file... to open the Choose a customization file dialog box. Select and load the desired partial customization file.
2.2 Migrating custom linetypes
LIN files store linetype definitions. BricsCAD provides two default LIN files that you can customize: default.lin for imperial linetypes and iso.lin for metric linetypes. To migrate custom linetypes, copy the required linetype definitions from these files. You can also store custom linetypes in a separate LIN file and load it in BricsCAD.
To migrate custom linetypes, locate each file, copy the custom linetype definitions or the custom LIN file, and save them in the corresponding BricsCAD file.
- Migrating imperial or metric custom linetypes
- Go to the AutoCAD® Support folder and open in a text editor the acad.lin file for imperial custom linetypes or the acadiso.lin file for metric custom linetypes. Scroll down to the User Defined Linetype section, select the definition of the custom linetype and copy it.
Then, go to the BricsCAD Support folder and open in a text editor the default.lin file for imperial custom linetypes or the iso.lin file for metric custom linetypes. Paste the definition of the custom linetype at the end of the file, then save and close it.
- Migrating custom LIN files
- Go to BricsCAD and run the LINETYPE command. Choose New to open the Load Linetypes dialog box and import your custom LIN file.
It is recommended to store the custom LIN files in the BricsCAD Support folder.
2.3 Migrating custom hatch patterns
PAT files store the definition of the hatch patterns. There are two default PAT files, one for imperial hatch patterns and another for ISO hatch patterns. Custom hatch patterns can also be stored in an alternative PAT file.
To migrate custom hatch patterns, locate each file, copy the custom hatch pattern definitions or the custom PAT file, and save it in the corresponding BricsCAD file.
- Migrating imperial or metric custom hatch patterns
- Go to the AutoCAD® Support folder and open in a text editor the acad.pat file for imperial custom hatch patterns or the acadiso.pat file for metric custom hatch patterns. Scroll down to the User Defined Hatch Patterns section, select the definition of the custom hatch patterns and copy it.
Then, go to the BricsCAD Support folder and open in a text editor the default.pat file for imperial custom hatch patterns or the iso.pat file for metric custom hatch patterns. Paste the definition of the custom hatch patterns at the end of the file, then save and close it.
- Migrating custom PAT files
- Copy and store the custom PAT files as needed. To migrate them in BricsCAD, choose one of the following:
- (Recommended) Go to the BricsCAD Support folder and save there the custom PAT files.
- Add the location of your custom PAT files to the Support file search path section in the Settings dialog box (SRCHPATH system variable).
2.4 Migrating custom drawing templates
Drawing templates are DWT files that store settings specific to the drawing and project requirements, such as units, layers, styles, layouts, etc.
To migrate custom drawing templates, locate each file, copy and save it in the corresponding BricsCAD folder.
Go to AutoCAD® and launch the OPTIONS command. Click the Files tab, go to the Template Settings section to find the location of the drawing template file and copy the files.
Then, go to BricsCAD and launch the TEMPLATEFOLDER command to open the folder where the drawing template files are stored. Paste the files.
2.5 Migrating custom plot files
Custom plot styles are stored in CTB or STB files. Plotter configurations are stored in PC3 files, and plotter model parameters associated with a PC3 are stored in PMP files.
- CTB and STB files are fully compatible. A drawing can use either CTB or STB plot styles, so the plot style table is displayed based on the current drawing plot style mode (see the CONVERTPSTYLES command article).
- In BricsCAD, PC3 plotter configuration files are supported only for Windows system printers, while AutoCAD® supports additional printer configuration types.
- Some PC3 configurations also require their associated PMP file when migrated.
To migrate custom plot files, locate each file, copy the files and save them in the corresponding BricsCAD folder.
- Migrating Color-Dependent Plot Style Table (CTB) or Named Plot Style Table (STB)
- Go to AutoCAD® and launch the STYLESMANAGER command to open the Plot Styles folder and copy the files.
Then, go to BricsCAD and launch the STYLESMANAGER command to open the PlotStyles folder and paste the files.
- Migrating Plotter Configuration File (PC3)
- Go to AutoCAD® and launch the PLOTTERMANAGER command to open the Plotters folder and copy the files.
Then, go to BricsCAD and launch the PLOTTERMANAGER command to open the PlotConfig folder and paste the files.
- Migrating Plotter Model Parameters (PMP)
- Go to AutoCAD® and launch the PLOTTERMANAGER command to open the Plotters folder. Open the PMP Files folder and copy the files.
Then, go to BricsCAD and launch the PLOTTERMANAGER command to open the PlotConfig folder. Open the PMP folder and paste the files.
2.6 Migrating custom tool palettes
BricsCAD supports importing tool palettes from XTP, ATC and BTC files, and tool palette groups from XPG and BWS files. Tool palettes can be exported to BTC files, and tool palette groups to XPG files.
BricsCAD stores tool palettes in BTC files and indexes all existing palettes in the BcTpCatalog.btc file. When you create or import a new palette, BricsCAD updates the catalog and automatically generates a separate BTC file that contains the content of the palette. All palette files are stored in the default Tool Palettes folder inside the Support directory.
To migrate custom tool palettes, export each file and import it into BricsCAD.
Go to AutoCAD® and launch the TOOLPALETTES command to open the Tool Palettes panel. Right-click the panel and choose Customize Palettes... to display the Customize dialog box. Then, right-click the custom palette or palette groups you want and select the Export... option to open the Export Palette or Export Group dialog box. Save the custom palette file as an XTP file or the custom palette group as an XPG file.
Then, go to BricsCAD and launch the TOOLPALETTES command to open the Tool Palettes panel. Right-click the panel and choose Customize Palettes... to display the Customize dialog box. Then, right-click any palette or palette group and select the Import option to open the Import Palette or Import Palette Group dialog box. Choose the XTP or XPG file you want to import.
2.7 Migrating custom command aliases
Command aliases are alternative names for commands, and they are saved in a PGP file.
To migrate custom command aliases, locate each file, copy the custom command alias definitions and save them in the corresponding BricsCAD file.
Go to the AutoCAD® Support folder, open the acad.pgp file in a text editor and scroll down to the User Defined Command Aliases section. Select the custom command alias definitions and copy them.
Then, go to the BricsCAD Support folder and open the default.pgp file in a text editor. Paste the custom command alias definitions at the end of the file, save the file and exit.
2.8 Migrating custom shape files
SHX files store the definition of the fonts and SHP files store the definition of the shapes. These files are usually stored in the Support folder.
To migrate custom shape files, locate each file and copy both the SHP and SHX files to the BricsCAD Support folder.
Go to the AutoCAD® Support folder and copy both the SHP and SHX files.
Then, go to the BricsCAD Support folder and paste the SHP and SHX files.
2.9 Migrating LISP files
LISP (List Processing) is an interpreted programming language used to automate tasks, create custom commands and extend BricsCAD functionality. LISP routines can interact with BricsCAD commands, system variables, dialog boxes and drawing entities.
BricsCAD is compatible with AutoCAD® AutoLISP, so it can load and run LSP files. However, the VLX and FAS file formats are AutoCAD® specific encrypted LISP files, and BricsCAD cannot load such files.
To migrate LISP routines, locate the desired LSP files, then copy and save them in the corresponding BricsCAD folder. LISP files are usually stored in the Support installation folder. These can also be stored in a folder whose path is added to the SRCHPATH system variable.
Two LISP files are automatically loaded in AutoCAD® from acad.lsp and acaddoc.lsp. The equivalents of these two files on BricsCAD are on_start.lsp and on_doc_load.lsp.
- Migrating ACAD.LSP into ON_START.LSP
- Go to AutoCAD® Support folder and open in a text editor the acad.lsp file. Select the custom content and copy it.
Then, go to BricsCAD Support folder and create a new text editor file named on_start.lsp. Paste the custom content and save it.
- Migrating ACADDOC.LSP into ON_DOC_LOAD.LSP
- Go to AutoCAD® Support folder and open in a text editor the acaddoc.lsp file. Select the custom content and copy it.
Then, go to BricsCAD Support folder and create a new text editor file named on_doc_load.lsp. Paste the custom content and save it.
- Migrating encrypted VLX files, FAS files, VLX projects (PRV) and FAS projects (PRJ)
- Compiled and encrypted VLX and FAS files cannot be loaded in BricsCAD. Migration of VLX and FAS based applications requires access to the original LISP source files and the PRV or PRJ project files.
BricsCAD supports the creation of encrypted applications through DEScoder.exe. Using DEScoder.exe, multiple LISP, DCL and other application resource files can be packaged and encrypted into a single DES application file. PRV and PRJ project files are used to define the application contents and generate the encrypted DES file.
- After migration, the on_start.lsp and on_doc_load.lsp files are loaded per session by default, but these can also be loaded for each drawing if the ACADLSPASDOC system variable is set to 1.
- Another way to load your LISP routines is with the APPLOAD command. After you run the command, the Load Application Files dialog box is displayed to select the application files you want to run inside BricsCAD. The AutoLoad option specifies whether a file is loaded automatically or not in the next BricsCAD session (see the Load Application Files dialog box article for more information).
The path of the DES Encoder is: C:\Program Files\Bricsys\BricsCAD V27 en_US.
- Open the encoder.
- Select the LISP file in the Source field.
- Click the Convert selected source Lisp file into DES encrypted file button next to the Target field.
- After the DES file is converted, copy it to BricsCAD Support installation folder: %AppData%\Bricsys\BricsCAD\V27x64\en_US, or to a folder whose path is added to the SRCHPATH system variable.
