Creating a drawing
There are several ways to create new drawings in BricsCAD:
  • In the Start tab.
  • Using the QNEW command.
  • Using the NEW command.
  • Using the NEWWIZ command.
  • Double clicking a *.dwt file in File Explorer.
Note: A new drawing is always created as a copy of a template drawing. The default template is saved through the BASEFILE system variable.
